SOLVED GV stopped connecting today
ariban
I have been using piaf green for the past many years running centos 6.5, today all of a sudden. all my google voice trunks using motif just stopped working, they are disconnected and wont connect.
i logged into my gv account to make sure its not asking me for a security question, the allow less protected apps is allowed in google security. i dont know what is happening nor how to fix it, anyone else seeing this issue?
Asterisk = ONLINE | Dahdi = ONLINE | MySQL = ONLINE │
│ Disk Free = ADEQUATE| Mem Free = ADEQUATE| NTPD = ONLINE │
│ PIAF Installed Version = 3.0.6.5 under *HARDWARE* │
│ FreePBX Version = 2.11.0.43 │
│ Running Asterisk Version = 11.12.0 │
│ Asterisk Source Version = 11.12.0 │
│ Dahdi Source Version = 2.10.0 │
│ Libpri Source Version = 1.4.15 │
│ IP Address = 192.168.1.10 on eth0 │
│ Operating System = CentOS release 6.5 (Final) >< │
│ Kernel Version = 2.6.32-431.29.2.el6.i686 - 32 Bit │
│ Incredible Version = 11.10
logs show this:
2016-05-22 21:51:17] WARNING[8948] res_xmpp.c: Parsing failure: Hook returned an error.
[2016-05-22 21:51:17] WARNING[8948] res_xmpp.c: JABBER: socket read error
[2016-05-22 21:51:17] ERROR[8949] res_xmpp.c: TLS connection for client 'gfaxgmailcom' cannot be established. OpenSSL initialization failed.
logs show this:
Turn on xmpp debugging and find the error. If it is a tls compatibility error you might need to upgrade OpenSSL.
so funny, this morning just started working again by itself!!
Hi. Same error here that started a few days ago. Each trunk would get into an endless loop of failures and retries with the above message printed to the log. I ended up deleting all of my GVoice trunks as they overwhelmed by router, hitting the 4,096 max number of outbound connections. I also received a couple of "unusual activity" warnings from Google search that I suspect were tied to the high number of failed TLS connections.
My OpenSSL and related packages are up to date. My impression was that it could have been related to an unsupported TLS cypher of sorts. If it's now working again for some, it might have been something on Google's side. I will try adding the trunks back in later today and see if its better.
Thanks,
JR
Hi all. Ok after enduring a few days of TLS related issues on my GVoice trunks, everything's working again now. I had not made any changes before and no changes were made since the last time they were failing. All GVoice trunks are now up and running.
Thanks,
JR
Anyone else started seeing the same SSL issue again since last night? I wish Jabber had a retry time setting instead of flooding it repeatedly when it can't connect.
Thanks,
JR
Started seeing this last night.
[2016-06-14 07:25:38] ERROR[4411]: res_xmpp.c:2560xmpp_client_requested_tls: TLS connection for client 'XXXXX' cannot be established. OpenSSL initialization failed.
[2016-06-14 07:25:38] WARNING[4411]: res_xmpp.c:3527xmpp_client_receive: Parsing failure: Hook returned an error.
[2016-06-14 07:25:38] WARNING[4411]: res_xmpp.c:3586xmpp_client_thread: JABBER: socket read error
So it just starts working after a while ? I have few trunks and this kills the vm and strains the firewall like crazy... I checked google accounts and they are working, updating all the packages on the box. Seems that all acounts are doing it, not just certain ones.
Yes, Jabber goes into a loop of reconnects and uses up every available connection socket until the firewall/router maxes out. If Jabber had a timeout or delay between connects, it would just fail to connect but not bring down everything around with it. I finally deleted all of my GVoice trunks. It's been a nice few years run but it's is now getting way too unstable.
Thanks,
JR
Could someone grab XMPP debugs of this while it is happening? It would be useful to see what is actually being exchanged with Google during this thrashing.
Thanks,
JR
Too bad you deleted, wanted to know if its happening to you as well right now.
It'll be intresting to know if its happening to all at the same time.
Im really hopping this will fix it self soon, if not I might be in the same boat and delete voice trunks via xmpp maybe go with the $5 solution, just I have few trunks.
As soon as I get in, I can try that, just set debug=yes in xmpp.conf ?
No, do it from the Asterisk console. "xmpp set debug on" or similar - wait a little while - then turn it back off. You'll find the debugs in the full log.
The console is over run with the messages I posted above, Ill try to do it from the console and post it here.
@billsimon, I have a set-up with multiple GV trunks. I'll go turn on debugging as well to see what surfaces...
(I wouldn't have noticed there was a problem. I don't use those trunks, or even that PBX, often. I still primarily use GV from an Obi100 when at home, and your gateway via Zoiper when on the road...)
You use what with Zoiper ?
So I have the log. In less then a minute I have a 3.1mb log with about 36000 lines...
https://www.zerobin.net/?a06e3fc8d657e57a#k1+vzs8oekbb5bP3ZpdFFbBU0H4huIazfPU95KfQAI8=
There is a bug report that matches this: https://issues.asterisk.org/jira/browse/ASTERISK-24712
There are four possible paths in this function that lead to the error message you are getting. http://doxygen.asterisk.org/trunk/dc/d6b/res__xmpp_8c.html#061c4cbf39cf2ba5a8d8175f2a6716ee
It seems like an OpenSSL compatibility problem.
What version of OpenSSL are you running?
Latest Posts
gandalf
