NEW iPBX 2026 Queue Callback beta4
The simplest solution to block all these calls is to add and save the following code immediately below [from-internal-custom] at the top of /etc/asterisk/extensions_custom.conf and then issue command: asterisk -rx "dialplan reload"
; Block international Caribbean/High-risk NANP calls
 exten => _NXXNXXXXXX,1,NoOp(Checking Dialed Number against Blocklist)
 exten => _268NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _284NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _345NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _473NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _649NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _664NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _721NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _758NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _767NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _784NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _809NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _829NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _849NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _868NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _869NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _876NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1NXXNXXXXXX,1,NoOp(Checking Dialed Number against Blocklist)
 exten => _1268NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1284NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1345NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1473NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1649NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1664NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1721NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1758NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1767NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1784NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1809NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1829NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1849NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1868NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1869NXXXXXX,2,Goto(app-blackhole,hangup,1)
 exten => _1876NXXXXXX,2,Goto(app-blackhole,hangup,1)
I just use an outbound route before the typical toll route. I route them to a recording. Easy to maintain. My dial plan is always 1NXXNXXXXXX for toll calls.
It seems for some reason the updates I made to your PBX were reverted somehow to the old code.
ahhhhhhhh ok ill remove the old code and reinstall beta 2...............
no. i reverted the changes. It is working now. The issue so far was with three files I directly made changes to your PBX. There is also a newer version of the module which has these changes, but you do not need to upgrade to it.
Edit: too late. I see you already reinstalled installed the old Module
Edit 2: I restored the updated files. Just check the operation only now
You keep putting the old module back on for some reason. It is working with the newest version, but you keep reinstalling the old version. Just stop and don't do do anything . Give me a few minutes then do nothing else but just test it. I need to again revert the broken files.
okay i patched the broken files. Go ahead and test
Thinking about it more....what if someone has legit business in one of those area codes. Perhaps make a tab with blocked area codes with all of the Caribbean blocked when the module is installed. Then they can manually remove one or more with the possibility of adding more to the list including international.
For now I am waiting on Feedback from Joe and from anyone else interested in testing it at this point.
Simple answer is to dial legit numbers with a prefix, e.g. 9. Then add that outbound route to the FreePBX dialplan.
ok so i have to experiment further, i think the queue announcement setting are interferring with the callback announcements, and i have to make more realistic announcements, i just selected a generic announcement, also under the queue information, you cannot cancel any callbacks or pending callbacks?
The three announcements are for the following:
1. The announcement of a callback. To let callers know there is an option to call back and what to press.
2. The call back number . This is to let users know what number they will be called back at and options available.The announcement is played AFTER the number is announced.There are not enough words in Asterisk to do this. It seems you put in an "not available" message in there which is being played after the number is called.
3. The announcement to play to the customer when they get their call to let them know their call from the queue and it is their turn.
At this point, we are just making sure the callback system works before adding more features.
I have tested locally with just extensions and it is working for me, but I need more real world testing done.
@Joe Diamond CPA: Here are two sample sound files you can use for qcallback.
cd /var/lib/asterisk/sounds/en/custom
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/queue-press*-to-request-callback.wav
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/queue-returning-your-call.wav
@KNERD is welcome to add these to his next tarball.
thanks..............thank you for including me in this project, it is very exciting! since i am retired setting up IPBX 2026 and VPBX 4.5 is a great time filler for me!, and keeps me out of my wife's hair! and now im back to drinking my beers at 5pm instead of noon! LOL
I still need to figure out how to add them to System Recordings during module installation as the configuration section has a drop down menu to add any available recordings
Latest Posts
clifford06
