NEW BulkVS has a Dynamic 911 offering now - no trunk required
Folks, this forum is for IncrediblePBX. You need to ask questions about Wazo and Grandstream UCM on their forums. Special handling is available for 911 in IncrediblePBX if you purchase the ClearlyIP modules.
Currently, you can set up BulkVS to send X-Header with BulkVS for 911 calls. They add it based on the CID number you send with the 911 call. I haven't tried it. Programming your own X-header may be available through direct Asterisk contexts.
Is there a script or module to use dynamic e911 with BulkVS? How are people adding and populating the required x-header per extension for outbound 911 calls?
Nobody is using this function in IPBX? Is there a better area to post this question?
