Cache Caller ID to PhoneBook for lookups
AndyInNYC
2 questions:
1. I have 16-15 running (or is it 15-16?). Do I need to change anything in the directions which are for 13-13?
2. Are there any directions for using bulkvs for the lookup for this process?
Getting tired of all the bs calls coming through along with the calls which should have ID against them but don't (our CVS drugstore doesn't show callerid info, for example).
Thanks in advance.
Andrew
2 questions:
Thanks in advance.
Andrew
Are you using Superfecta? Superfecta has the options to to use the Phonebook and also to cache prior lookups to bulkVS
