SOLVED Call from a different DDI, from specific extension
nelitojr
Hello people from the World! I'm from Portugal!
I need some help please...
I have a magic Incredible PBX®working perfect.
I bought a new DDI (trunk) and is configured in my pbx. But I need only a specific extension call by this DDI. Example:
I have ext 101, 102, 103, etc... calling by DDI (trunk) "1122334455" and now I want the ext 201 calling by my new DDI (trunK) "99887766".
I had 1 outbound route with my old DDI. Now I made a 2nd outbound route with the new trunk on " Trunk Sequence " and put the " Dial Pattern" with "match pattern" and "callerID" as the new extension and don't work. I tried to put the "callerID" the new trunk number and din'd work too. The out number is allways the 1st one I have in "outbound".
I hope I'ved explainned...I'm not a very good english...
Thanks in advance!!
You've explained yourself very well, your English is fine.
What you have completed is correct, and should work, almost. I think you need to move the 2nd route, above the first * Apply. Then what will happen is the system will only allow calls on that Route from ext 201, and then forcing the other extensions to move on to the next Route. Give that a try.
Hello Mr
Thanks for your solution. Works perfectly.....
Amazing.
Thanks.
