BUG GVSIP Script Created Trunks Need to Be Manually Re-Created to Work
ilovepancakes95
When creating a GVSIP trunk using built in script, the trunk gets added and appears in GUI but outbound routes cannot select, save, and use that trunk. Upon Apply Config the route just goes back to having no trunk selected. If I copy the custom string from the script created trunk to a new custom trunk I create myself in GUI, the routes can now save the trunk selection and outbound calling works.
Can't understand why the auto created trunk by script would have something messed up in it that doesn't allow it to work.
make sure to set an outbound CID on the Google voice trunk
Don't think I ever set one when I recreated the outbound trunk manually to get it to work. I do have an outbound CID set on the individual extensions though.
