Incredible PBX 2021 - Remote Endpoints etc.
Joe Diamond CPA
Good morning and god bless everyone. I have completed another learning project in my quest for becoming a competent PBX'er. I have set up Incredible PBX 2021 on Crown Cloud. I highly recommend Crown Cloud, they have the best tech support and competitive pricing. I have 8 PBX's there that I practice and try to learn on (mostly destructive learning LOL). Anyway, follow Wards's instruction https://nerdvittles.com/morphing-incredible-pbx-into-a-public-facing-cloud-pbx/ , but in addition what I have accomplished in registering remote endpoints outside the local whitelisted network (android or apple) is using a WireGuard server on Crown Cloud Ubuntu. I used this script on the wireguard app on my android, the Keys are generated by the server and the Endpoint IP is the IP of the Ubuntu server running wireguard. I can now, for the first time register and make calls without the complex and tedious Travlin Man (don't get me wrong, Travlin Man is awesome), just I am not smart enough to know how to implicate it. Also, for those of you who want to set up a PJSIP trunk (problem not with a SIP trunk), if you run into the issue of dialing out on a REMOTE ENDPOINT, not a local whitelisted endpoint "all circuits are busy now" .....here is the fix...........under trunk, pjsip, advanced, make sure "from domain" (ip of the pbx server) and "from user" (the voip privider account, I use Voip.ms, so i put my sub account there, XXXXXX_incredible), are entered, also scroll down to "trust RPID/PAI" and select yes, "send RPID/PAI to both. Fixed! Just one more step closer to going public and maybe commercial! with Incredible PBX!
[Interface]
Address = 10.7.0.3/24
DNS = 8.8.8.8, 8.8.4.4
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
[Peer]
PublicKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
PresharedKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = 104.194.222.3:51820
PersistentKeepalive = 25
Greatest and warmest thanks goes out to Ward, of which none of this would be possible without Ward's genius.
Just for your own edification, Incredible PBX is a fork of the FreePBX project with some branding and some modifications like disabling signature checks, etc. It has ClearlyIP modules for commercial functionality in replacement of the FreePBX commercial modules (which can't be used by Incredible PBX).
90%+ of what is in Incredible PBX was not designed, developed or is maintained by Ward. If one of your modules has a bug and isn't working right, you have to file a report with either Sangoma or ClearlyIP (depends on module). If you want new features or improvements to existing modules like Ring Groups, Outbound Routes, Queues, etc... in Incredible PBX. Same thing, you need to request it from Sangoma or ClearlyIP depending on who is maintaining said module.
thank you, sorry I did not know that Samot, no disrespect intended, I just wanted to show Ward my gratitude for all the great articles written helping no so smart individuals like myself as I have learned much of what i know (which is not very much) from individuals like Ward, i will heed your advice and thank you for responding and enlightening me, joe Just so you know Samot, I am an avid FreePBX user that has purchased many commercial modules, I just use Incredible PBX as a learning tool.
You'll have to excuse @Samot. He undervalues everyone's contributions... except his own. Oh wait. Where are those?
Yet what I stated is still true, unless you have somehow developed and published a bunch of those modules in FreePBX that I am unaware of. Perhaps a ClearlyIP module? Is there a place here that deals with bugs and feature updates of these modules in their own stream outside of FreePBX or ClearlyIP?
As for my contributions, those go to the upstream. This project has no clear-cut structure for such thing outside of making forum posts. So since I've solved issues in forums posts, I guess that counts.
Because you're too lazy to look, let me give you just a brief list of free components in Incredible PBX that you won't find at all in Sangoma's distro or the FreePBX product. Feel free to list yours as well, @Samot. We'll wait... In the meantime, you might want to brush up on what a System Integrator is and does.
User-customizable Asterisk/FreePBX installers for Rocky 8, Debian 10 & 11, Ubuntu 20.04, Raspbian
User-customizable images for VirtualBox, VMware, Proxmox, and Raspberry Pi
Preconfigured, free faxing with HylaFax and AvantFax
Preconfigured, secure IPtables firewall
Preconfigured, secure Fail2Ban
Preconfigured PortKnocker
Preconfigured NeoRouter VPN
Preconfigured OpenVPN
Preconfigured, secure WebMin
Preconfigured SendMail and Postfix
Preconfigured ODBC Integration for FreePBX
Sample ODBC Database Lookups for FreePBX
Dozens of Preconfigured Trunk Provider Setups for FreePBX
Preconfigured, secure PUBLIC Access Setups for FreePBX
Preconfigured scripts to update CentOS, Debian, Ubuntu, Raspbian, and Rocky
Preconfigured scripts to update or upgrade Asterisk
Preconfigured scripts to update or upgrade FreePBX
Preconfigured scripts to update or upgrade PHP
Preconfigured script to implement PPTP
Preconfigured script to implement TFTP
Preconfigured script to implement SAMBA
Preconfigured script to implement Gmail Smarthost for SendMail/Postfix
Preconfigured script to implement non-Gmail Smarthost for SendMail/Postfix
Automatic Update Utility to resolve bugs and security vulnerabilities
Integrated TTS apps for Asterisk and FreePBX (FLITE, Festival, PicoTTS, GoogleTTS, Amazon Polly)
Integrated TTS apps for Voicemail Transcription
Integrated STT apps and samples for Asterisk and FreePBX
AsteriDex 4 web-based MySQL GUI with FreePBX Dialer & Lookups
Telephone and Web-Based Reminders for FreePBX with Email and SMS Alerts
TTS News Headlines for FreePBX
TTS Weather Forecasts for FreePBX (by ZIP Code and Airport Code)
CallerID Superfecta for Asterisk
MailCall for Asterisk via TTS
SMS Scripts for Skyetel and VoIP.ms Message Blasting
Speech-to-Text Directory Assistance for Asterisk
Wolfram Alpha TTS for FreePBX
U-Rang Screenpop Utility for Asterisk
xTide TTS for FreePBX
Teleyapper Message Broadcasting System for Asterisk
Scripts to disable Module Signature Checking with FreePBX
Script to configure time zones worldwide
Incredible Backup and Restore Utilities for all OS platforms
Correct, these are the parts of Incredible PBX that you have contributed/developed. I never said you didn't do that. Incredible PBX is a fork of FreePBX and it runs ClearlyIP commercial modules, that is fact. You spent time and effort on all the above, that's really cool. This is fact too.
But that list was rather informative, I've learned something and now I understand better.
Ward is doing a great service to the community by putting in his time and effort with no financial motive. I have been following Ward from asterisk@home days (2004-2005). He is the reason how I got introduced to Linux, bash scripts, VoIP and many other things. He has shown a path to numerous members here in this forum and also people from all around the world. All this, with only "spirit of service" and distribution of his knowledge.
His contribution is immense.
I totally agree, ward got me interested and gave me a great opportunity to learn and be part of a great community here with intuitive tutorials. thanks ward and everyone else too
