TRY THIS IncrediblePBX 13-13-LEAN fails on fresh CentOS 7
Mike Wayne
I told Ward but putting this here as a warning to others.
Fresh VM at Vultr running CentOS 7 x64
Followed the install instructions at http://nerdvittles.com/?p=23948 exactly, multiple times. After the scripts does the first reboot, there is no way to log in to the machine, even in single user mode from the console. Tried a second account using tcsh, that can not log in either so something very vital is getting corrupted. Server is online but it seems that no shell works.
There is an issue with the code that updates the nameserver. I commented out the reboot and went looking. Saw this in etc:
[root@r3 /etc]# ls -l res*
-rw-r--r--. 1 root root 65 Nov 29 00:34 resolv.conf
-rw-r--r--. 1 root root 47 Nov 29 01:51 resolv.conf? echo nameserver
That ? is a <LF>. And of course resolv.conf has the original values that Vultr installed and is now immutable.
But this should not prevent logins
Will look into this with CentOS 7. CENTOS 7 IS NOT RECOMMDED!!
Immediate fix goes like this:
chattr -i /etc/resolv.conf
echo "nameserver 8.8.8.8" > /etc/resolv.conf
chattr +i /etc/resolv.conf
reboot
reboot
And I've encountered that even on Centos 6 on Vultr, so not only a Centos 7 issue.
Gave up on CentOS 7. There's a lot of code in the install script suggesting that 7 is supported but I did not want to mess with it. Vultr does not offer 6.10 installs anymore so I had to do an ISO install. Might want to mark 7 as unsupported in he script like the 32 bit version already is.
First part of install seemed to go cleanly, so it's an issue with 7.
Found (and fixed) a minor issue with fail2ban (the mkdir needs to have the -p option).
The upgrade to Whole Enchilada uses tput, instead of the more correct stty so it gets the wrong values for terminal size. For a quick fix, before running
./Enchilada-upgrade.sh
export the LINES and columns with
export LINES
export COLUMNS
and the size check will work correctly. To correct the script to work correctly, use the following lines in place of the ones using tput:
COLUMNSIZE=`/bin/stty -a | /bin/grep columns | /bin/sed 's/^.*columns \([0-9]*\);.*/\1/'`
LINESIZE=`/bin/stty -a | /bin/grep rows | /bin/sed 's/^.*rows \([0-9]*\);.*/\1/'`
Installer has been fixed. There was an extra set of quotes at the end of the echo lines. Bug indeed! Thanks.
Huh? We just tested two CentOS 6.x installs at Vultr this morning.
Might be available because you installed it before? I don't get that option:
@Mike Wayne: Thanks for the fixes. We've updated the installer. The screen sizing code is no longer needed at all and will be removed when we take out the Google Voice stuff. If you want to work through the CentOS 7 install failures and post your notes, we'll be glad to incorporate the changes. Thanks again.
@Mike Wayne: I think we've gotten the remaining kinks out of the CentOS 7 64-bit install. Try a fresh install and let us know how it goes. Part of the problem has been the CentOS folks continually moving the goalposts. Our apologies.
