SOLVED No fax detection available for incoming routes
Eliad
I have a new install for IncrediblePBX and this version no longer has the fax detection tab option for the incoming routes. I know this option was available in prior versions.
Is there a way to get this option installed?
Problem solved. This new version does not have the Fax module enabled by default. Once enabled the problem is solved.
