DoubleDriveLine
- Sep 23, 2017
- 144
- 46
Well I am heading down this twisted road of trying to get sendmail on the PBX to function with my email server. I have tried it about 4 other times and always given up and gone down the ssmtp route. Like Bullwinkle and Rocky "This time I know you will get it for sure!"
I am closer than I have been before. I am finally sending the email as the right account but not getting authenticated.
I have followed the instructions here http://nerdvittles.com/?p=31290 and used the sendmail.mc.gmail file but modified it to use my server as the smarthost.
I had to deviate slightly to get the system to transmit the correct email address to the server as the sending email. In genericstable I had to add the below code.
This changes the sending email address from [email protected] to example1@mypersonalDomain. Naturally the email server does not like the root account because it is not present.
After that bit of code makemap has to be run again on the genericstable file.
In the sendmail.mc file Here are the only mofifications I have made that deviate from the tutorial.
The code in my client-info file is as follows. Initially I had the I: value as the full email address. Then when double checking everything before I go to post this I found Ward's wording "# Replace user_id with your gMail account name without @gmail.com". I had missed the @domain name and am not sure if for me it is necessary or not. I have tried it both ways.
For referance the server name is pbx2020.mypersonalDomain.something and has been added to the hostname and hosts file. The server is virtual Centos 7 running in VMWare at my site.
Here is the maillog entry from a test email sent from the command line while logged in as root
This is the typical server error message in the /var/log/exim_rejectlog file
I send the test message using the sendmail command. The issue seems to be I am never sending the log on credentials. They should be sent after the marker below. Here is a link to a working example. https://access.redhat.com/solutions/60803 scroll down to this section "To test the authentication, send an email to remote MTA using following command:".
Any help is greatly appreciated.
I have pretty much run out of ideas and again spent way too much time on sendmail.
For reference here is the response from the server when using the openssl test.
root [email protected]
makemap -r hash genericstable.db < genericstable
define(`SMART_HOST', `mail.mypersonalDomain.something')dnl
TRUST_AUTH_MECH(`EXTERNAL DIGEST-MD5 CRAM-MD5 LOGIN PLAIN')dnl
MASQUERADE_DOMAIN(mypersonalDomain.something)dnl
AuthInfo:mail.mypersonalDomain.something "U:smmsp" "I:[email protected]" "P:{password cleared}" "M:PLAIN"
AuthInfo:mail.mypersonalDomain.something:587 "U:smmsp" "I:[email protected]" "P:{password cleared}" "M:PLAIN"
AuthInfo:mail.mypersonalDomain.something:465 "U:smmsp" "I:[email protected]" "P:{password cleared}" "M:PLAIN"
AuthInfo:mail.mypersonalDomain.something: "U:root" "I:example1" "P:{password cleared}" "M:PLAIN"
AuthInfo:mail.mypersonalDomain.something:587 "U:root" "I:example1" "P:{password cleared}" "M:PLAIN"
AuthInfo:mail.mypersonalDomain.something:465 "U:root" "I:example1" "P:{password cleared}" "M:PLAIN"
root@pbx2020:~ $ tail -f /var/log/maillog
Sep 18 08:25:07 pbx2020 sendmail[29192]: 08ICOqDh029192: from=root, size=81, class=0, nrcpts=1, msgid=<[email protected]>, relay=root@localhost
Sep 18 08:25:08 pbx2020 sendmail[29192]: STARTTLS=client, relay=mypersonalDomain.something., version=TLSv1/SSLv3, verify=FAIL, cipher=ECDHE-RSA-AES256-GCM-SHA384, bits=256/256
Sep 18 08:25:08 pbx2020 sendmail[29192]: 08ICOqDh029192: [email protected], ctladdr=root (0/0), delay=00:00:16, xdelay=00:00:01, mailer=relay, pri=30081, relay=mypersonalDomain.something. [IPAddress], dsn=5.1.1, stat=User unknown
2020-09-17 21:08:52 H=3.sub-174-x-x.x [IPAddress] (pbx2020.mypersonalDomain.something) [IPAddress]:6359 X=TLS1.2:ECDHE-RSA-AES256-GCM-SHA384:256 CV=no F=<[email protected]> rejected RCPT <[email protected]>: SMTP AUTH is required for message submission on port 587
root@pbx2020:/etc/mail/auth $ sendmail -Am -v -t
To: [email protected]
Subject: Test Message
Body of the message
[email protected]... Connecting to mypersonalDomain.something. port 587 via relay...
220-server1.hostingServer ESMTP Exim 4.93 #2 Fri, 18 Sep 2020 08:22:00 -0400
220-We do not authorize the use of this system to transport unsolicited,
220 and/or bulk e-mail.
>>> EHLO pbx2020.mypersonalDomain.something
250-server1.hostingServer Hello 3.sub-174-x-x.x [IPAddress]
250-SIZE 52428800
250-8BITMIME
250-PIPELINING
250-STARTTLS
250 HELP
>>> STARTTLS
220 TLS go ahead
250-SIZE 52428800
250-8BITMIME
250-PIPELINING
250-AUTH PLAIN LOGIN
250 HELP #<---- After this there should be the log in credentials but they never show up. The Server goes straight to sending the email.
>>> MAIL From:<[email protected]> SIZE=81
250 OK
>>> RCPT To:<[email protected]>
>>> DATA
550 SMTP AUTH is required for message submission on port 587
/root/dead.letter... Saved message in /root/dead.letter
Closing connection to mypersonalDomain.something.
root@pbx2020:/etc/pam.d $ openssl s_client -connect mail.mypersonalDomain.something:587 -starttls smtp
CONNECTED(00000003)
depth=3 C = GB, ST = Greater Manchester, L = Salford, O = Comodo CA Limited, CN = AAA Certificate Services
verify return:1
depth=2 C = GB, ST = Greater Manchester, L = Salford, O = COMODO CA Limited, CN = COMODO RSA Certification Authority
verify return:1
depth=1 C = US, ST = TX, L = Houston, O = "cPanel, Inc.", CN = "cPanel, Inc. Certification Authority"
verify return:1
depth=0 CN = server1.hostingServer
verify return:1
Certificate chain
0 s:/CN=server1.hostingServer
i:/C=US/ST=TX/L=Houston/O=cPanel, Inc./CN=cPanel, Inc. Certification Authority
1 s:/C=US/ST=TX/L=Houston/O=cPanel, Inc./CN=cPanel, Inc. Certification Authority
i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority
2 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority
i:/C=GB/ST=Greater Manchester/L=Salford/O=Comodo CA Limited/CN=AAA Certificate Services
Server certificate
-----BEGIN CERTIFICATE-----
{...SNIP}
-----END CERTIFICATE-----
subject=/CN=server1.hostingServer
issuer=/C=US/ST=TX/L=Houston/O=cPanel, Inc./CN=cPanel, Inc. Certification Authority
No client certificate CA names sent
Peer signing digest: SHA512
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 5348 bytes and written 450 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-GCM-SHA384
Session-ID: {...SNIP}
Session-ID-ctx:
Master-Key: {...SNIP}
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1600426978
Timeout : 300 (sec)
Verify return code: 0 (ok)
250 HELP
250-SIZE 52428800
250-8BITMIME
250-PIPELINING
250 HELP
^C
