TIPS Signalwire phone numbers and SMS in Incredible PBX 2027
pbxfreeck
Is it possible to integrate Signalwire phone numbers and SMS in Incredible PBX 2027?
For SMS or fax you will need to create webhooks, which would require some programming knowledge I am afraid, I have don't have the knowledge to help you,
For phone / SIP they have an easy to follow instructions:
I haven't actually used the guide but let me know if you need more help.
I've used Signalwire phone numbers with pre-2027 versions of IncrediblePBX for years without issue, based on tips and hints in this forum. However, I have never tried to integrate Signalwire numbers for SMS...
@billsimon probably has what you're looking for. I don't know if Signalwire has been added yet or not. Have a read here for more details.
I have a number of SMS solutions built around SignalWire including a text-for-trail status application for biking enthusiasts. The PHP is pretty simple and the stability is great, but you do have to go through the 10DLC crap. Note we also use the ability to route a voice call into a readback of the current status for those that prefer to call instead of text.
