SOLVED Use of standard Sip client with 3CX
amorosik
Can I connect a standard sip software client, like MicroSip or Linphone or similar to 3CX extensions ?
You probably could like any other SIP capable device by why not use the 3CX clients that work the best with 3CX?
I have used other Android or IOS that in my opinion are better than the 3CX client, Maybe the 3CX client works best with 3CX, but there are others out there that have worked better
Because the sources code are not available and any modification is impossible to do
The 3CX client for Android or IOS is one of the best clients out there.
My question was not
"which is the best client for 3CX"
but "..is it possible to use standard Sip client software with 3CX? "
The point is that there is no "client better than another"
But surely there is a "client for me better than the others"
It all depends on what you have to do with it
Many users> => many different needs
It is impossible to define "the best client"
Conversely, "the best client for me" is easily identified
As to clients, SIP is SIP. Any system which accepts SIP will accept a SIP client at the standard level of SIP definition. Add-on features are what make clients different. Download some clients and try them for yourself since you're looking or the best client for "you." Enjoy.
Obviously I will look for the software that best suits my needs
The question was whether 3CX could support a standard sip client
