SOLVED Where is Session-Timers settings in Incredible PBX GUI?
vchohan
Hi Team,
I am unable to find Session-Timers settings in the Incredible PBX GUI. Could you please help me with this? I want to set Session-Timers settings from accept to refuse because all calls are disconnecting after 15 minutes. (I believe this will resolve the issue)
When I tried to change this setting through the terminal, it says this setting should be changed through GUI.
It isn't in the settings, it's a manual setting you add to SIP settings (or additional sip settings). You could probably also put it in sip_custom.conf or one of the custom addendum files.
I tried to do the same, but I still see Accept in the Sip settings even after reloading the SIP.
2436
2437
I don't think that's the right nomenclature / formatting for it.
I think it's session-timers=refuse
*think*
