chris_c_
- Aug 19, 2010
- 658
- 116
Fresh install of Incredible PBX with Asterisk GUI for Ubuntu 14.04 32 bit on Virtualbox 512MB VM.
Followed this how to:
http://nerdvittles.com/?p=12181
Connectivity is OK from the notebook Yate sip client, to the desktop (running the PBX VM). The SIP login works fine, call extension 6002 and leave a voicemail, checking voicemail works, and the yahoo news app works.
Added a dedicated set of google voice credentials to the proper area of Asterisk GUI, "Incredible PBX apps / Google voice". They saved ok.
Try to make a call to a normal US phone number by entering 10 digit US phone number in yate and click the call icon. It rings about 20 times then yate seems to give up and hang up. The actual phone being called, fails to ring. Leads you to believe the call didn't actually go through. The Asterisk call log inside the Asterisk GUI show the call. Not sure what actually happened.
Looked on this forum, on another google voice thread, and found a suggestion from WM to go thru a google voice "display unlock captcha" process to looosen up some of the possible security restrictions google might have been applying that might've prevented the call from working. https://accounts.google.com/b/1/DisplayUnlockCaptcha
Tried to make a call from yate thru the PBX to the same US phone number.
Now it behaves totally differently.
Asterisk service stops running, and the web interface logs out.
Check in the logs.
asterisk segfault libikseme1.so.3.0.0
Anyone else experience this?
How to fix it?
Check in the logs.
How to fix it?
