ALERT RTP stream security risk
and Incredible PBX for Raspbian:
sed -i 's|-A INPUT -p udp -m multiport --dports 10000:20000 -j ACCEPT|\#-A INPUT -p udp -m multiport --dports 10000:20000 -j ACCEPT|' /etc/iptables/rules.v4
sed -i 's|-A INPUT -p udp -m multiport --dports 10000:20000 -j ACCEPT|\#-A INPUT -p udp -m multiport --dports 10000:20000 -j ACCEPT|' /etc/iptables/rules.v4.ubuntu14
I applied the above on Raspbian, no errors but
when I did nano on /etc/iptables/rules.v4, nano couldn't find "-A INPUT -p udp -m multiport --dports 10000:20000 -j ACCEPT" (using ctrl+W )
Instead I found
-A INPUT -p udp -m udp --dport 10000:20000 -j ACCEPT
but no #. Also no mention of multiport
Same thing in rules.v4.ubunto14.
Shouldn't these code lines be included in the root logon updates utility?
I'm a little bit confused, I read this post on Blog Nerd Vittles Blog: "RTPbleed Security Alert: Asterisk Calls Can Be Intercepted" so for curiosity I just start to look at iptables and I did not find the line: -A INPUT -p udp -m udp --dport 10000:20000 -j ACCEPT , I find this line: -A INPUT -p tcp -m tcp --tcp-flags ACK ACK -j ACCEPT.
After that I start to read this post I seams to me that @wardmundy already fixed the problem with the new install of 13-13 ( I made mine13-13 in last november), so I do not need to do any action, right?
TIA
TIA
Correct. It's been addressed.
