SOLVED How to whitelist blocked hosts/IPs
jolebole
Hello guys,
I just installed new IncrediblePBX 13.13 but I ended up with some blocked IPs in the rules that I dont know how to remove. Check my rule output bellow. A, B and C IP addresses are blocked right now. How can I remove them from here or white list them. Thanks
Chain FORWARD (policy ACCEPT)
target prot opt source destination
Chain OUTPUT (policy ACCEPT)
Chain f2b-ASTERISK (1 references)
REJECT all -- A.A.A.A 0.0.0.0/0 reject-with icmp-port-unreachable
REJECT all -- B.B.B.B 0.0.0.0/0 reject-with icmp-port-unreachable
REJECT all -- C.C.C.C 0.0.0.0/0 reject-with icmp-port-unreachable
RETURN all -- 0.0.0.0/0 0.0.0.0/0
Chain f2b-BadBots (1 references)
Chain f2b-SSH (1 references)
Chain f2b-asterisk-tcp (1 references)
Chain f2b-asterisk-udp (1 references)
fail2ban-client set asterisk unbanip 12.34.56.78
Then edit /etc/fail2ban/jail.conf and add the IP addresses in the ignoreip variable list and restart Fail2Ban: service fail2ban restart
Mr. Mundy for the rescue. Thanks a lot!!! :clap:
