NO JOY Voicemail MWI (Message Waiting Indicator light) random delay
domiflichi
Hello,
I have a fairly fresh, and up-to-date Incredible PBX 13-13 system (on actual hardware - not a VM).
I've got 3 phones (Snom 320s) connected to the system currently (more later) and I've noticed a problem with the voicemail notification light. When a voicemail is left for that extension, sometimes the light will start blinking properly right away, sometimes there will be a delay of a few minutes to around half an hour. It seems fairly random. And similarly, once the voicemail is checked, the light will sometimes stop blinking right away, sometimes it will take a few minutes before it stops, sometimes it will be around half an hour before it stops blinking.
I can go into the Snom's web interface and force the extension to re-register and this seems to update the light immediately.
The voicemail notification email gets sent immediately every time.
I don't think it's the phones because the same phones are also on an older PBX-In-A-Flash system and the lights 'update' immediately every time for those extensions.
On my install of 13-13 for a new client I've noticed the same but with GrandStream and Yealink.
Had to install 13-12 to meet my deadline
Just finished another (latest) 13-13 and will be testing later
I just looked at my 'pbxstatus' and I have 13-13.8. So something seems to be wrong with my system in particular...any hints on the kind(s) of things I should look at to get it working?
Add the new FreePBX modules and see if that doesn't fix your issue. Tutorial here. Let us know how it goes.
Thanks for the suggestion. Followed the instructions to upgrade the modules, rebooted, but still no joy.
Not sure if this helps at all, but I'm putting a piece of a log from one of the Snom phones below. I have the log level set to 7 currently.
So I left a voicemail then immediately cleared the log. One thing to note is that this phone has 2 SIP extensions registered, both with the same extension #, 115. The main one is to 10.10.10.200 (this is our old/existing PiAf system), the one that's having the issue is to 10.10.10.198 which is the new Incredible PBX system that I'm talking about in this thread.
[5] 6/3/2019 09:53:41: send lldp advertisment
[6] 6/3/2019 09:54:03: webserver::request 19: GET /log.htm HTTP/1.1
[5] 6/3/2019 09:54:41: send lldp advertisment
[5] 6/3/2019 09:55:41: send lldp advertisment
[5] 6/3/2019 09:56:41: send lldp advertisment
[5] 6/3/2019 09:57:41: send lldp advertisment
[5] 6/3/2019 09:58:41: send lldp advertisment
[5] 6/3/2019 09:59:41: send lldp advertisment
[5] 6/3/2019 10:00:41: send lldp advertisment
[5] 6/3/2019 10:00:49: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:01:07: Resetting SRTP
[5] 6/3/2019 10:01:07: rtp_port::set_destination  adr=10.10.10.200:16996
[6] 6/3/2019 10:01:07: find_function_key_for_uri: Looking to match sip:[email protected]:2173;line=du9hqff0
[6] 6/3/2019 10:01:07: find_function_key_for_uri: Looking to match Unknown <sip:[email protected]>
[6] 6/3/2019 10:01:07: Line-Seize subscription was not sent
[5] 6/3/2019 10:01:07: Dialog -10/8 going to early
[7] 6/3/2019 10:01:07: GUI: set_led: nr 13 id 14 state 3
[7] 6/3/2019 10:01:07: GUI: set_led: nr 0 id 13 state 3
[5] 6/3/2019 10:01:07: rtp_port::set_port
[5] 6/3/2019 10:01:14: Dialog -10/8 going to terminated
[5] 6/3/2019 10:01:14: rtp_port::set_destination RP-10 adr=
[7] 6/3/2019 10:01:14: GUI: set_led: nr 13 id 14 state 0
[7] 6/3/2019 10:01:14: GUI: set_led: nr 0 id 13 state 0
[5] 6/3/2019 10:01:14: set_audible: RP-10 changed=0, update_req=1, adr=
[5] 6/3/2019 10:01:41: send lldp advertisment
[5] 6/3/2019 10:02:31: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:02:41: send lldp advertisment
[5] 6/3/2019 10:03:41: send lldp advertisment
[5] 6/3/2019 10:04:34: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:04:41: send lldp advertisment
[5] 6/3/2019 10:05:41: send lldp advertisment
[5] 6/3/2019 10:06:41: send lldp advertisment
[5] 6/3/2019 10:07:41: send lldp advertisment
[5] 6/3/2019 10:08:41: send lldp advertisment
[5] 6/3/2019 10:09:04: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:09:19: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:09:41: send lldp advertisment
[5] 6/3/2019 10:10:16: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:10:41: send lldp advertisment
[5] 6/3/2019 10:10:49: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:11:41: send lldp advertisment
[5] 6/3/2019 10:12:22: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:12:41: send lldp advertisment
[5] 6/3/2019 10:13:41: send lldp advertisment
[5] 6/3/2019 10:14:41: send lldp advertisment
[5] 6/3/2019 10:15:41: send lldp advertisment
[5] 6/3/2019 10:16:23: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:16:41: send lldp advertisment
[5] 6/3/2019 10:17:06: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:17:26: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:17:41: send lldp advertisment
[5] 6/3/2019 10:18:41: send lldp advertisment
[5] 6/3/2019 10:19:41: send lldp advertisment
[5] 6/3/2019 10:20:41: send lldp advertisment
[7] 6/3/2019 10:20:46: NTP: on_ntp_packet() 1: start
[7] 6/3/2019 10:20:46: NTP: on_ntp_packet() 2: resend.pending
[7] 6/3/2019 10:20:46: NTP: on_ntp_packet() 3: refresh.callback timeout after 3600 seconds
[2] 6/3/2019 10:20:45: start_dst(1552183200) end_dst(1572746400) offset_dst(3600) offset_utc(-28800)
[2] 6/3/2019 10:20:45: start DST: 03/10/2019 02:00:00 (1552183200)
[2] 6/3/2019 10:20:45: end DST: 11/03/2019 02:00:00 (1572746400)
[6] 6/3/2019 10:20:46: SIP: reregister timer for line 0 set to 300s
[7] 6/3/2019 10:20:46: Trusted IP Addresses: udp:10.10.10.200
[5] 6/3/2019 10:20:46: sip::process_auth:Match challenge for user=115, realm=asterisk
[2] 6/3/2019 10:20:46: Registered at registrar as [email protected] (Expires: 3600 secs)
[7] 6/3/2019 10:20:46: settings::Set: outgoing_identity = '1', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 6/3/2019 10:20:46: settings::Set: outgoing_identity = '2', set.need_apply: 0, finished: 1, need reboot to apply: 0
[6] 6/3/2019 10:20:46: SIP: reregister timer for line 1 set to 300s
[7] 6/3/2019 10:20:46: Trusted IP Addresses: udp:10.10.10.198
[7] 6/3/2019 10:20:46: GUI: set_led: nr 0 id 13 state 4
[5] 6/3/2019 10:20:48: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 6/3/2019 10:21:40: send lldp advertisment
[6] 6/3/2019 10:22:40: webserver::request 20: GET /log.htm HTTP/1.1
So I left the voicemail at around 9:53, and the light didn't start flashing until around 10:20. It seems to correspond to the 'Registered at registrar as [email protected]' line, which isn't that surprising given that I can force the phone to re-register from the web interface which seems to trigger the voicemail light
So I used the same phone for my next little test. I cleared the phone's log, then left myself a voicemail on the 1st line (the one that is connected to our older PBX-In-A-Flash system), and copied the phone's log:
[5] 7/3/2019 15:52:12: rtp_port::set_port
[6] 7/3/2019 15:52:12: Line-Seize subscription was not sent
[7] 7/3/2019 15:52:12: GUI: set_led: nr 13 id 14 state 1
[6] 7/3/2019 15:52:13: Hook switch released
[5] 7/3/2019 15:52:13: set_audible: RP30 changed=1, update_req=0, adr=
[6] 7/3/2019 15:52:13: set_additional_addresses
[5] 7/3/2019 15:52:13: Dialog 30/80 going to trying
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_remote = '*115', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_time = ' 3:52PM', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_duration = ' 0:00', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_local = '[email protected]', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_duration = ' 0:29', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_remote = '*97', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_time = ' 3:48PM', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_duration = ' 0:08', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_remote = '1120', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_time = ' 5:56AM', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_remote = '*80112', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_time = ' 5:55AM', set.need_apply: 0, finished: 1, need reboot to apply: 0
[7] 7/3/2019 15:52:13: settings::apply_value: callrecord_dialed_duration = ' 0:01', set.need_apply: 0, finished: 1, need reboot to apply: 0
[5] 7/3/2019 15:52:14: sip::process_auth:Match challenge for user=115, realm=asterisk
[5] 7/3/2019 15:52:14: Dialog 30/80 going to proceeding
[5] 7/3/2019 15:52:14: Dialog 30/80 going to confirmed
[2] 7/3/2019 15:52:14: SIP: Process timer without requiring timer
[2] 7/3/2019 15:52:14: SIP: Session timer refresh 1800 sec by remote
[5] 7/3/2019 15:52:14: Resetting SRTP
[5] 7/3/2019 15:52:14: rtp_port::set_destination RP30 adr=10.10.10.200:18484
[5] 7/3/2019 15:52:14: set_audible: RP30 changed=0, update_req=1, adr=10.10.10.200:18484
[6] 7/3/2019 15:52:32: Hook switch pressed
[7] 7/3/2019 15:52:32: settings::apply_value: callrecord_dialed_duration = ' 0:18', set.need_apply: 0, finished: 1, need reboot to apply: 0
[5] 7/3/2019 15:52:32: Dialog 30/80 going to terminated
[0] 7/3/2019 15:52:32: Deleting connected_call
[7] 7/3/2019 15:52:32: GUI: set_led: nr 13 id 14 state 0
[6] 7/3/2019 15:52:32: SIP: packet 1007647 stopped retransmission
[6] 7/3/2019 15:52:32: SIP: packet 1007649 stopped retransmission
[5] 7/3/2019 15:52:32: set_audible: RP30 changed=1, update_req=0, adr=10.10.10.200:18484
[5] 7/3/2019 15:52:32: set_audible: RP30 changed=0, update_req=0, adr=10.10.10.200:18484
[7] 7/3/2019 15:52:32: GUI: set_led: nr 0 id 13 state 4
[6] 7/3/2019 15:52:44: webserver::request 65: GET /log.htm HTTP/1.1
The MWI light comes on immediately (as always, and as expected). Not sure if this is helpful...I know I can't really make any sense of it.
