SOLVED How can I make a phone immediately call another extension when picked up (Like a doorphone)
nateornat
Im' running Incredible PBX 13-13, I have a couple guest phones that we want to call immediately to an extension, when they are picked up. They do not need to call anywhere else. I think this can be done through the dial-plan somehow, but not sure. Maybe custom context? You assistance would be greatly appreciated. Thanks
What you are looking for is commonly referred to as "hotline" service. Asterisk/FreePBX/IncrediblePBX have no way to do this for SIP telephones. It may be possible if using analog phones via DAHDI or with some analog terminal adapters. For SIP devices, it is normally accomplished on the device as a feature on that phone. You'll need to research your phone features for your devices. Check for hotline, autodial, etc. to see if such a feature is available on your device.
As Kenn10 said, it is a function you will find via your phone, not the PBX. Grandstream are pretty decent cheap phones to do this with, and you can find this under Call Feature -> Off-Hook Auto Dial.
On Yealink, it is under Features -> Hotline Number.
If I recall, you can also accomplish this function using an ATA and a basic analogue phone. Even better if you can find a phone with no dial or keypad. Programm the ATA to immediately dial any number, or extension.
Perfect, I was using Grandstream Phones, and it was right where you said, and was very simple to do. Thanks again everyone! Awesome forum once again!
