David Foxworth
- Oct 26, 2013
- 69
- 23
Just a heads up that, if you use OVZ7 at anyNode, you'll need to open a ticket to get IPtables functioning properly. This is apparently an issue with the SolusVM Control Panel using OVZ7 VPSs.
To add to this list, OpenVPN is unable to create the tun interface, and I have a ticket open and believe that Matthew is working to fix. However, he did get my iptables stuff working, except the GeoIP stuff. So commands such as "iptables -m geoip" will fail.
On a positive note, it appears that ipset is working, so I can use the bad guy blacklist. I would also suspect that NeoRouter might have an issue if it has to create a virtual interface device.
