TRY THIS Upgrade path to 2020 from 13-13 on Centos 6.10?
JFrost
As the title. Is there an upgrade path from 13-13 running on 6.10 (in Vultr if that matters) to the latest 2020 (which I think requires centos 7?)
Thanks.
@ostridge Not sure I follow? I don't need a script necessarily but is there an article/instruction/how-to I can follow? Can you point me to it?
ty
Ok ty. Looks like I'll need to block out some weekend time for this. @wardmundy one question - should I go 13-13 to 16-15 FIRST and then go 2020 or you think will be fine to go straight to 2020?
Either way snapshot and daily backups at Vultr for sure.
Thanks.
@wardmundy Tried the upgrade per here: http://nerdvittles.com/?p=30365
When I get to this part
In addition to the whitelisting procedure above, there are three more steps to complete on the Incredible PBX 13-13 server. First, you’ll need to update the backup module:
./gpl-install-fpbx backup
I don't have that script in my /root dir.
Where do I get it or please how to proceed?
Not got a 13-13 but I think that means in the gui under Admin tab > Module Admin - then see if the
Backup and Restore or whatever its called is in there and maybe update it??
I DO have that option in my GUI but that snippet specifically says it's to "update the backup module". So not sure if my current GUI backup is good enough or missing something or what but either way that is a CLI instruction and I'm missing it so need advice on how to proceed.
Also, this may be a typo in the article, not sure.
@wardmundy can you advise here please?
thx.
That script is in the gpl toolkit https://pbxinaflash.com/community/threads/gpl-toolkit-for-incredible-pbx.22787/#post-136596 if you don't have the toolkit installed (and I don't) but I just downloaded it to my PC and the script 'gpl-install-fpbx' is in there. The rest of it seems to comprise repos to install and lists to find the modules to download via 'gpl-install-fpbx' and the parameter 'backup' is the name of the file to install. So the instructions for that bit of your migration are in the above link.
