App Memory and Disks high, how can i fix?
Markman1
PIAF Free PBX System status shows 55% disk use and 41% App Memory. Both seem high. Do you have any suggestions where I should look or how I can easily delete old logs that might be causing this?
Thanks for you help.
Mark
Really need more info. What type of system? Hardware / Memory - Hosted Location if applicable.
What is top telling you about the memory - what's eating it?
What version of PIAF are you using?
As far as deleting logs ... look in /var/log - if asterisk logs /var/log/asterisk
A command that I use often to see where my disk is being eaten is:
du -sh *
du -sh *
maybe more complete
sudo du -hx --max-depth=1 /|sort -h
