Well I think we will have some great news for non Clearly IP phones for provisioning in the very very near future.
That will be awesome. Please include Yealink phones too.Well I think we will have some great news for non Clearly IP phones for provisioning in the very very near future.
do you have better instructions on how to install it?
for me it fails at tar command with
tar zcvf yealinkv80.tgz yealinkv80
tar: yealinkv80: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
Thank you.View attachment 2808
Then under Brands -> Package Manager, you'll find tab for Yealink V80
@krzykat and anyone else actively using OSS EPM who may have a test system spun up - I would appreciate it if you could try https://github.com/jerrm/endpointman/archive/release/14.0.zip and report what behaves differently than OSS EPM 14.0.2.1.
Code fixes are the easy part, but I haven't had any meaningful time to test.
The goal of the updates is just to get things running and functionally equivalent under php-7.3/mysql-10.3.22 for debian folks like myself, but also maintain compatibility with IPBX's(and Sangoma Distro's) php-5.6/mysql-5.5.64.
The only existing "bug" addressed is the setup.php issue mentioned by @krzykat above (it just got too annoying to leave alone). Hopefully there would be no other functional changes over 14.0.2.1 (but fully expect there are still issues to address).
*** BE SURE TO HAVE A BACKUP OR SNAPHOT ***
This makes minor mods to the EPM tables if upgrading an existing OSS EPM install. Current mysql versions require explicitly setting some default values that were previously implict... But that is part of what needs testing - does a null mysql blob/text column (new explicit default) behave differently than an empty blob/text (old implicit default).
If anyone cares to take the time to test under Debian, I can spin up an instance and provide access.
No worries. Any help appreciated, whenever convenient.I'll do as requested, but will have to be this evening, I'm working on converting a client from the old incredible 13-12 to Incredible 2020 right now.
Is port 69 for t*f*t*p open thru your firewall?I am trying to configure three Polycom VVX 500s using this. I have them set up to use t*f*t*p and the IP is set to the IncrediblePBX IP. They cannot contact the provisioning server though, is it just not working with Polycom phones at the current time?
Figured it out, installing a t*f*t*p server in CentOS 7 configures it to look at /var/lib/tftpboot instead of /tftpboot for the config files. Once I made that change all is good.
In this post in this thread #15, the pic shows a GXP2140 in the list. Where did you get that, I get the 2130 and 2160 only I HAVE 2140s and would like to use OSS EPM. Where can I find the GXP2140 template ?? Thanks
Live Chat
Video Conferencing
Check your inbox!
