TIPS Incredible 13-13 on raspi upgrade to Incredible2020 on raspi
Prits
Hello,
  1. What is the best upgrade path/method/steps to move from Incredible 13-13.10raspi to Incredible 2020raspi on the same device?
  2. Does the provided script: incrediblebackup13 work to backup this version and then restore using this backup on a fresh Incredible2020 raspi install?
Thank you
I have the following system:
Incredible PBX 13-13.10 for Raspberry Pi 2B
Asterisk: UP Apache: UP MariaDB: UP
SendMail: UP IPtables: UP SSH: UP
GV OAUTH: UP Chan-SCCP: UP NR VPN: UP
FaxGetty: UP IAX Modem: UP HylaFax: UP
RAM:176684 Raspbian (Jessie) Disk:24G
Asterisk 13.22.0 + GUI ver. 13.0.122.60
Private IP: 192.168.0.109
Public IP: XX.XX.XX.XX
System Time: Thu Jul 16 11:17:49 MST 2020
Cut and paste will give you a clean installation and if something doesn't work you will know it's a configuration problem and not an issue you imported from the old version.
