SOLVED Asternic CDR Reports Module Unsigned
aroundi
Hello,
After updating modules, I have an Unsigned Module warning (Asternic CDR). The license field is blank. Is there a procedure to correct this?
Running IPBX 2020 x86_64
Be sure to click like on my post with the solution. :D
FYI: Asternic CDR module croaks with Incredible PBX 2021 on Debian 10 platform. Same for OSS Endpoint Manager.
If I were to take my OSS Endpoint Manager t*f*t*p files from Incredible PBX 2020 would Incredible PBX 2021 be able to serve the files over t*f*t*p? I know I wouldn't be able to easily update them, but at least it would keep me from having to re-program all the phones manually right away.
Yes. T*F*T*P is independent of the PBX. You'd just need to set it up on the new Debian system and move the files to your preferred directory.
See https://wiki.debian.org/t*f*t*p
and https://www.cyberciti.biz/faq/install-configure-t*f*t*p-server-ubuntu-debian-howto/
