w1ve
- Nov 15, 2007
- 842
- 223
Hey Folks,
Here I've been messing with third-party SIP clients on my Android phone, and I've been very unhappy with any of them.
Come to find out, there has been a NATIVE SIP CLIENT built into Android since Version 6.0.
I'm currently on a Pixel 4XL with Version 10.0, so YMMV, and the menu locations may be slightly different, but I've tested this with a few
Friends, including some Samsung Galaxy phones, and same.
What's nice about the native client?
- As many SIP accounts as you want.
- SIP-to-SIP dialing, no need for registration
- Receiving calls works fine.
- Calls are in the native Call Log on Android -- so you can call back automatically.
This is awesome to integrate corporate PBX extension with your regular cell.
It is calling over 4G or Wifi, but I seem to be having great luck with it. I'd like to hear others feedback.
How to:
- Go to the native dialer on android, and click the three-vertical-dot menu:
- Select Settings:
- Select Calls
- Select Calling Accounts:
Here, you see I already have a SIP account, and my Visible regular 4G SIM-based cellular account.
Notice the Make Calls With setting. If you select "Always ask", when you dial a number it will prompt you to select the Account (see later picture).
To set up a new SIP Account, select SIP Accounts.
If you want to receive incoming calls on the SIP account, check the selection. This will register with the PBX.
- Setting up new SIP Account:
Click the + in the upper right to create a new account:
Your username is your extension on the PBX.
Your password is the password for your extension on the PBX.
The server is your FQDN of your PBX.
Under Optional Settings:
I put in my extension as the autenticated username
Display name is your name (as you want it to be displayed)
Outbound Proxy Address is the FQDN of your PBX.
Port and transport per your PBX Configuration.
As I said,if you select "Always Ask" for "Make Calls With" setting, the dialer will prompt you for the account:
Here's what I see when I dial a pbx extension and press the call button:
Simply tap the account you want to use!!
As I said, it is integrated, works over 4G or Wifi, and is seemless. YMMV.
Gerry
How to:
- Select Settings:
- Select Calls
Gerry
