@wardmundy and
@ostridge , for those that logged into their console and the auto update utility ran prior to this fix, what do we do to fix this issue because when I log back into the console and let the auto utility run, it already thinks this update has been applied?:
This update utility goes to IncrediblePBX.com to retrieve the latest updates.
We test updates before release, but NO WARRANTY EXPRESS OR IMPLIED IS PROVIDED.
Your voluntary financial support of this update service is most appreciated.
To make a contribution using any credit card, please visit
http://nerd.bz/QwQkYO
To proceed solely at your own risk, press Enter. Otherwise, Ctrl-C to abort.
Retrieving... lastupdate2020
Updates available as of Wed Sep 30 09:12:08 MST 2020: 20
Checking for update20201. INSTALLED: Automatic Update Utility is working
Checking for update20202. INSTALLED: Patches for Incredible PBX 2020.3 Raspbian
Checking for update20203. INSTALLED: ClearlyIP repo configured for updates
Checking for update20204. INSTALLED: Incredible PBX 2020.3 Raspbian CDR patch
Checking for update20205. INSTALLED: Incredible PBX 2020.3 AsteriDex patch
Checking for update20206. INSTALLED: FreePBX GPG Key Refresh
Checking for update20207. INSTALLED: halt and reboot scripts added
Checking for update20208. INSTALLED: timezone-setup update for Raspbian 10
Checking for update20209. INSTALLED: TM3 add-fqdn update for IPv6 use
Checking for update202010. INSTALLED: Raspbian 10 Incredible Fax installer updat e
Checking for update202011. INSTALLED: Incredible PBX 2020.3 pbxstatus LAN port p atch
Checking for update202012. INSTALLED: NV-Weather-ZIP patch for 0 zip codes
Checking for update202013. INSTALLED: Incredible PBX 2020.3 amd.conf patch
Checking for update202014. INSTALLED: LAME aadded for voicemail processing
Checking for update202015. INSTALLED: watson-test STT script added to /usr/local /sbin
Checking for update202016. INSTALLED: Wolfram Alpga AGI script updated
Checking for update202017. INSTALLED: Asterisk 16 update script patched
Checking for update202018. INSTALLED: Removed Asterisk duplicate logging
Checking for update202019. INSTALLED: AvantFax MySQL patch for Raspbian
Checking for update202020. INSTALLED:
Updates and notifications completed.
To continue, press the Enter key...
