Trying to move from incredible pbx on raspberry pi to incredible pbx on centos - restore fails
Fribse
I've done a backup on the raspberry pi, and I'm trying to do a restore on the centos 7 machine, but I get this message:
Processing fax
Resetting fax module data
Updating tables fax_details, fax_incoming...Done
Generating CSS...Done
Restoring from fax [FreePBX\modules\Fax\Restore]
Importing KVStore from fax
Whoops\Exception\ErrorException: Call to undefined function fax_save_settings() in file /var/www/html/admin/modules/fax/Fax.class.php on line 287
Stack trace:
  1. Whoops\Exception\ErrorException->() /var/www/html/admin/modules/fax/Fax.class.php:287
npm WARN deprecated [email protected]: Package no longer supported. Contact [email protected] for more info.
npm WARN deprecated [email protected]: This version of 'is-buffer' is out-of-date. You must update to v1.1.6 or newer
PHP Fatal error:  Call to undefined function fax_save_settings() in /var/www/html/admin/modules/fax/Fax.class.php on line 287
I have updated all the modules on the destination system.
I'm not sure that sort of backup/restore is supported.
I did this moving from Centos version to Raspi version.
Try to do the backup and restore from the FreePBX GUI. You might be able to get most of the settings move over the Centos version.
The iptables entries are of course not transferred. You will have to do that manually.
Ok, I've just entered the information from the raspberry pi to the new centos box, it isn't really a big setup.
One thing that I can't remember is the hylafax destination, how did I do that ? :)
Most
the new centos box
most if not all the ipbx tutorials (probably?) tell you to do a full incrediblebackup2020 pn the newly installed system; or else a clone of your system disc / card. Of course its up to yourself to balance the risks.
Most
Yup, that's what I did, a complete new install, and then just entering all the info again.
I'm mostly done, got the fax working (partly), I am running into challenges with the mail setup again.
Well thats best asked in annother post. Dont forget to include system info and info details of the problem.
Don't forget to
/root/incrediblebackup2020
always do a backup first.
