SOLVED DAHDI NOT FOUND [Suggest Uninstalling the Dahdi Configuration Module]!
ostridge
While doing ./incrediblebackup2020.3
on Raspbian10 RPi3b incredible2020 Asterisk 16.13.0 Gui 15.0.12.33
GUI Dashboard saying
File /etc/dahdi/modules does not exist. (neither does that folder exist?)
Please run 'touch /etc/dahdi/modules' and then 'fwconsole chown' to create this file.
File /etc/dahdi/system.conf does not exist.
Where do I find the module to do this: DAHDI NOT FOUND [Suggest Uninstalling the Dahdi Configuration Module ?]
Stopped Clearly Anywhere Daemon
Running Asterisk pre from Clearlytrunking module
Clearly Client Server is not running
Running Asterisk pre from Core module
Running Asterisk pre from Ucp module
Stopping UCP Node Server
[>---------------------------] 2 secs
Stopped UCP Node Server
Shutting down Asterisk Gracefully. Will forcefully kill after 30 seconds.
Press C to Cancel
Press N to shut down NOW
[============================] < 1 sec
Creating backup. Please wait...
Are you using DAHDI? If not you can probably ignore the message.
If you don't use DAHDI you can disable it:
From FreePbx Administration web intterface:
- Admin => Module Admin
- Look for DAHDi Config and expand it
- Click on Disable
- Apply
Now fwconsole restart will no more complain about DAHDI NOT FOUND
