Thank you for the answer @fmateo05 ... I’m not so technically minded so I will wait until I know that you have a start-up script to help me out.Yes, you can run them on VPS. My current cluster run this kind of install. You should upload the ISO to the VPS, open the console and run the Text-installer on it. during the first boot, all PBX services will start up. The step required here is to change the SIP-Proxy listen ip other than 127.0.0.1 and als oun some startup 'sup' commands (I am working to create a startup script to ease the post-configuration).
The goal of these ISO's is to ease the Kazoo installation and configuration.
How many VPS’s should I have for cluster setup if that is the route I want to go oppose to installing it all on one VPS?
thank you
