NO JOY Errors updating Admin/Modules
ostridge
Errors:
Installing restart
Untarring..Done
Error(s) installing restart:
    Failed to install Bulk Phone Restart due to the following conflicting module(s): OSS PBX End Point Manager
    Installing ucpnode
Untarring..Done
icu is not installed. You need to run: yum install icu libicu-devel
Error(s) installing ucpnode:
    Failed to run installation scripts
    Installing xmpp
Untarring..Done
Updating tables xmpp_users, xmpp_options...Done
MongoDB is not installed
Error(s) installing xmpp:
1) Bulk phone Restart - I presume needs a downgrade of OSS EPM
2) For ucpnode the required libraries not available (on Raspbian 10 Buster. apt install icu libicu-devel BOTH NOT FOUND.
I managed to install with apt install libicu-dev # NOT libicu-devel but not found icu ??
3) I don't think that XMPP is needed or have I missed something?
I'm pretty sure you don't need ucpnode or xmpp.
Do this from the Admin > Modules screen:
Uninstall all three (UCP Node Server, XMPP, Bulk Phone Restart.) Apply changes. Reinstall bulk-restart.
Looks like OSS Endpoint manager is still a no go on IncrediblePBX2021. If you don't install the Bulk Restart module, does the OSS work? I think a number of people have posted that it is not working.
