Existing IncrediblePBX install runs great. I have a SIP trunk which is 1 hop away on a private subnet (Digium PRI gateway). I am adding a SIP trunk from an external provider and the link to that is a direct Internet IP that I've added as a second NIC. So I have a couple of private subnets setup with localnets and the external net is currently the old IP and NAT=never.
I've tried to make this work with an IP route to the -host of the new SIP trunk and leaving the default gateway as the private IP VLAN and that doesn't work. I've tried changing the external IP in SIP settings and that doesn't work.
If I disable the existing eth device then the external trunk works but I'm not able to get both at the same time. I would have thought that IP routing would handle this but I was apparently wrong. Any advice would be greatly appreciated!
