Hi,
First post here but have been following for quite a while, lots of good information!
I signed up for BulkVS but I've not been able to get the LRN lookup to work.
The instructions say: Example 1: http://lrn.bulkCNAM.com/?id=(YOUR ID)&did=(TELEPHONE NUMBER)&ani=(TELEPHONE NUMBER)&format=simple
But what ID should I use? Tried both the account username as well as my API token but nothing works. I've opened a ticket with them to check their support.
Also, is anyone using them with LCR? I could of course import a route with
1,USA,0.004
but then I run the risk of sending traffic to Barbados, Canada, directory assistance etc. Does anyone have a csv file that can be used? How do you handle the 80%/20% RBOC/non-RBOC termination requirement?
Edit: They already replied to my ticket, that was fast! The answer is to use the SOAP API KEY as the ID.
1,USA,0.004
