wardmundy
Nerd Uno
- Oct 12, 2007
- 20,217
- 5,974
Are you planning on a "bring it with you guide" like you have done with previous releases?
Just updated versions or any new functionality?Incredible PBX 2020.3 release will be available in about an hour. It has updated modules plus latest Asterisk release.
Can I use this version with the older RPI version 3B? This one is not the B+ model.
I know this is an old thread... I used this script some time ago to get to Asterisk 16.17 on Raspberry Pi4, Raspbian 10. However today I tried to get to Asterisk 16.18 which is current. I get the following error...Updating Asterisk 16 to latest release is easy:
Code:cd /root wget http://incrediblepbx.com/update-asterisk16-raspi.tar.gz tar zxvf update-asterisk16-raspi.tar.gz rm -f update-asterisk16-raspi.tar.gz ./update-asterisk16
Sorry to use a slightly political phrase but:The existing menuselect.makeopts file did not specify
that 'test_scope_trace' should not be included. However, either some
dependencies for this module were not found or a
conflict exists.
so you mean try running it again.Have you actually tried to run the script?? It should sort this out. If make runs successfully, you're good to go. Otherwise, let me know.
post the alert message??
configure: creating ./config.status
config.status: creating makeopts
config.status: creating autoconfig.h
configure: Menuselect build configuration successfully completed
.$7$7.. .7$$7:.
.$$:. ,$7.7
.$7. 7$$$$ .$$77
..$$. $$$$$ .$$$7
..7$ .?. $$$$$ .?. 7$$$.
$.$. .$$$7. $$$$7 .7$$$. .$$$.
.777. .$$$$$$77$$$77$$$$$7. $$$,
$$$~ .7$$$$$$$$$$$$$7. .$$$.
.$$7 .7$$$$$$$7: ?$$$.
$$$ ?7$$$$$$$$$$I .$$$7
$$$ .7$$$$$$$$$$$$$$$$ :$$$.
$$$ $$$$$$7$$$$$$$$$$$$ .$$$.
$$$ $$$ 7$$$7 .$$$ .$$$.
$$$$ $$$$7 .$$$.
7$$$7 7$$$$ 7$$$
$$$$7. $$ (TM)
$$$$$$$. .7$$$$$$ $$
$$$$$$$$$$$$7$$$$$$$$$.$$$$$$
configure: Package configured for:
configure: OS type : linux-gnueabihf
configure: Host CPU : armv7l
configure: build-cpu:vendor:os: armv7l : unknown : linux-gnueabihf :
configure: host-cpu:vendor:os: armv7l : unknown : linux-gnueabihf :
CC="cc" CXX="g++" LD="" AR="" RANLIB="" CFLAGS="" LDFLAGS="" make -C menuselect CONFIGURE_SILENT="--silent" menuselect
make[1]: Entering directory '/usr/src/asterisk-16.18.0/menuselect'
gcc -g -D_GNU_SOURCE -Wall -DHAVE_NCURSES -I/usr/include/libxml2 -c -o menuselect.o menuselect.c
gcc -g -D_GNU_SOURCE -Wall -DHAVE_NCURSES -c -o strcompat.o strcompat.c
gcc -g -D_GNU_SOURCE -Wall -DHAVE_NCURSES -c -o menuselect_stub.o menuselect_stub.c
gcc -o menuselect menuselect.o strcompat.o menuselect_stub.o -lxml2
make[1]: Leaving directory '/usr/src/asterisk-16.18.0/menuselect'
Generating input for menuselect ...
menuselect/menuselect --check-deps menuselect.makeopts
conflict exists.
Either run 'make menuselect' or remove the existing
menuselect.makeopts file to resolve this issue.
make: *** [Makefile:364: menuselect.makeopts] Error 255
conflict exists.
Running Incredible PBX shutdown...
Try adding
#!/bin/bash
echo "This utility updates Asterisk 16 to the very latest release."
cd /usr/src
rm -rf asterisk-16*
wget http://downloads.asterisk.org/pub/telephony/asterisk/asterisk-16-current.tar.gz
tar zxvf asterisk-16*
rm -f asterisk-16*.tar.gz
cd asterisk-16*
make distclean
tar zxvf /root/menuselect*.tar.gz
./configure --with-pjproject-bundled --with-jansson-bundled
make menuselect.makeopts
make && make install && ldconfig
fwconsole restart
asterisk-16.18.0/utils/utils.xml
A addons/mp3
A addons/mp3/common.c
A addons/mp3/huffman.h
A addons/mp3/tabinit.c
A addons/mp3/Makefile
A addons/mp3/README
A addons/mp3/decode_i386.c
A addons/mp3/dct64_i386.c
A addons/mp3/MPGLIB_TODO
A addons/mp3/mpg123.h
A addons/mp3/layer3.c
A addons/mp3/mpglib.h
A addons/mp3/decode_ntom.c
A addons/mp3/interface.c
A addons/mp3/MPGLIB_README
Exported revision 202.
Hit http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit http://archive.raspberrypi.org/debian buster InRelease
Ign http://download.webmin.com/download/repository sarge InRelease
Hit https://packages.sury.org/php buster InRelease
Hit https://deb.nodesource.com/node_11.x buster InRelease
Hit http://download.webmin.com/download/repository sarge Release
Hit https://packages.ntop.org/apt/buster_pi armhf/ InRelease
Hit https://packages.ntop.org/apt/buster_pi all/ InRelease
## install completed successfully
checking for .... [***various ***]
****Asterusk text graphic****
/root/update-asterisk16: line 16: menuselect/menuselect: No such file or directory
conflict exists.
conflict exists.
#!/bin/bash
cd /usr/src
rm -rf asterisk-16*
cd asterisk-16*
make distclean
fwconsole restart
cd /usr/src/asterisk-16.18.0/menuselect
ls
Makefile contrib menuselect.o
README example_menuselect-tree menuselect_curses.c
autoconfig.h install-sh menuselect_gtk.c
autoconfig.h.in linkedlists.h menuselect_newt.c
config.guess make_version menuselect_stub.c
config.log makeopts menuselect_stub.o
config.status makeopts.in missing
config.sub menuselect strcompat.c
configure menuselect.c strcompat.o
configure.ac menuselect.h test
Live Chat
Video Conferencing
Check your inbox!
