SOLVED IncredibleFax header?
undrhil
SOLVED: From Ward Mundy: "
@undrhil Substitute your new heading for FaxoMatic below:
sed -i "s/IncredibleFax/FaxoMatic/g" /var/spool/hylafax/etc/config.ttyIAX0
sed -i "s/IncredibleFax/FaxoMatic/g" /var/spool/hylafax/etc/config.ttyIAX1
sed -i "s/IncredibleFax/FaxoMatic/g" /var/spool/hylafax/etc/config.ttyIAX2
sed -i "s/IncredibleFax/FaxoMatic/g" /var/spool/hylafax/etc/config.ttyIAX3
Where can I change the header that displays on a fax sent through IncredibleFax? In the top left of the faxes, it shows IncredibleFax and I would like to have it show my company name, if that's possible.
@undrhil , change your desired variables in this file and restart apache2 or reboot PBX to take effect:
/var/www/html/avantfax/includes/local_config.php
Have you read through the Hylafax / Avantfax tutorial?
I did read through it and the info I need isn't there.
I looked through this file and I don't see where it sets 'IncredibleFAX' anywhere, so the variable I'm looking for isn't in this file.
To be clear, I'm referring to this text where it says 'From IncredibleFax'
@undrhil ,
So it not at lines 106 to 110 in the following file??:
Also, if you want please take a look at these files and a reboot will be needed after the edits:
/etc/iaxmodem/iaxmodem-cfg.ttyIAX0
/etc/iaxmodem/iaxmodem-cfg.ttyIAX1
/etc/iaxmodem/iaxmodem-cfg.ttyIAX2
/etc/iaxmodem/iaxmodem-cfg.ttyIAX3
Change the cidname and cidnumber values
The above will help display correct info in CDR for outgoing calls.
@undrhil ,
The entries on these lines are blank.
None of these entries contain the text 'IncredibleFax'
I swear I did not see IncredibleFax in those files when I looked previously but this worked. Thank, you Ward!
Thank you both @undrhil and @wardmundy , This has been driving me crazy trying to figure out how to change it.
