SOLVED Update whitelist IP service
Brianmac
If I already have: IP whitelisted using the script: ADD-IP and only selected 1,2(SIP UDP & TCP)...
ow can I update that WAN IP with another service, e.g. 6 = FTP?
Thanks,
brian
Thanks,
brian
/root/del-acct followed by /root/add-ip with level of access needed.
Make not of the IP before you delete it. Then re-add it with required accesses.
OK, so delete then re-whitelist....
I was just adding a new name, e.g. /root/add ip abc1 xxx.xxx.xxx.xxx
Thanks!
Brian
I always like to keep these ip and fqdn accounts together in the /root/ directory - to that end I use prefix to the 'name'
Bash:
/root/add-ip ip-<accountname> xxx.xxx.xxx.xxx
# and for fqdn
/root/add-fqdn fq-<accountname> example.com
Of course that could be coded into the script.
