Halea
Well-Known Member
- Aug 12, 2016
- 1,164
- 917
I'm trying to add an MOH stream to an older IncrediblePBX system, on which in the past I always successfully used something like:
/usr/bin/mpg123 -q -s --mono -r 8000 -f 8192 -b 0 http://icecast.radiofrance.fr/franceinfo-midfi.mp3
The new source that I'm trying to make work is encoded in AAC format which doesn't seem to be compatible with mpg123.
Would you know of any other command line player similar to mpg123 that can playback AAC streams and can be used with freepbx/asterisk?
If you wonder what the stream looks like the following is a perfect specimen:
(The actual stream that I'll be using is a licensed source, not the one above, but its format is identical to the one above)
It can be played (and analyzed) with ffplay (from the ffmpeg toolkit). Unfortunately I can't get ffplay to cooperate with freepbx/asterisk.
If anyone has experience in doing so that might be my answer.
TIA
TIA
