path to call event log
alexhaj
hi I have incredible pbx 2021 and I see a massive call event log but I don't know where they are stored in the file system? plz help
Check in /var/log and associated subdirectories. The full Asterisk log is usually /var /log/asterisk /full.
They are stored in a mysql database in /var/lib/mysql/asteriskcdrdb .
No, but look into /var/spool/asterisk/recording/ , thy are generally divided into sub-directories /YEAR/MONTH/DAY file name identify source ,destination and two forms of date. The UNIQUEID field in the cdr and cel tables can be used to cross reference the recording names.
are the ogg recordings stored in the database as well?
I think it depends on which stream ...
may be in /var/spool/asterisk/recording/
OR look in /var/spool/asterisk/monitor/<yyyy>/<mm>/<dd>/
where that is /year/month/date
#For example I have mine as .wav
root@incrediblepbx:~# ls /var/spool/asterisk/monitor/2022/04/19
rg-s-01615202778-20220419-143208-1650375128.22.wav
