I upgraded my trial account to pay-as-you-go. I was then able to provision a free really powerful (sort of) VM.
Shape: VM.Standard.A1.Flex
OCPU count: 4
Network bandwidth (Gbps): 4
Memory (GB): 24
I used the OCID: ocid1.image.oc1.me-dubai-1.aaaaaaaamjtlzd67o5r5jkmrrkgx4jv3zfjc4xymi5yn6rlyjxfljqxh6x3a
(found here)
This is all free. I can resize this to some ridiculous amount of OCPU count and memory for free.
I noticed that in the screenshot it shows the Shape: VM.Standard.A1.Flex is showing "always free" for your VM.Standard.A1.Flex always free
BUT I have in my 'Compute Instances ' page where I have (see below)
The A1 Flex is not showing 'always free' though 'E2.1micro' does show that; QUERY is it same in your 'Compute instances' page still showing 'Always Free'?
instance-202110xx-xxxx -------------ExtIP   10.0.0.x VM.Standard.A1.Flex  4ocpu 24GB
instance-202110xx-xxxx Always Free ExtIP   10.0.0.y VM.Standard.E2.1.Micro 1ocpu 1GB
My A1-Flex never show as "Always Free" on the screen but they did when I created them. I have never had any billing for them. One thing I discovered is that if you don't delete the disk file when you delete your instance, you run out of capacity to recreate instances due to limitations on free storage. I've had 2 E1's and 4 A1's up at the same time for testing.
Not ure why mine shows Always Free. But the account is upgraded. NO charges. We'll give it a few months and if it stays that way or if they'll eventually catch up.
I signed up for the Pay As you Go and freaked out when I get an email saying Oracle had charged my CC $100. It was cancelled immediately though. I guess they just want to be sure that much credit is available in case of high usage.
How long does it take to do the upgrade?
I did the upgrade, and see, yes, the Ampere is still free. However, the AMD servers are no longer available for free.
Oracle is preventing me from building any new instances, well it was fun while it lasted.
I choose to build, it goes to provisioning, and then fails stating I have no available instances free and to upgrade from free.
You can have two E2 instances and four A1 instances. You have to make sure you have erased the boot files when you delete an instance or it will not let you create new ones. It also takes about 24 hours for a deleted instance to disappear and allow more to be created.
Look at your block storage/boot files and delete unused ones that are still there.
I have found if you upgrade to paid, you will not only still get the four A1 instances for free, but guaranteed have them available to you. With the free plan, it is about impossible to get them now.
@tbrummell: Here are the Oracle Cloud rules that we use without problems. Some are redundant due to earlier experimentation.
Hi Ward
2 questions
In this screenshot it says "stateless YES" for the All Protocols ingress and egress, but on the Free Oracle blog post at nerdvittles you say it should be Stateless NO - "In the Default Security List option, add Ingress and Egress Rules with an entry for Stateless=No, Source=0.0.0.0/0, IP Protocol=ALL, Source & Destination Port Range=ALL."
1) should it be stateless YES or stateless NO?
also, this rule which you specify seems to open ALL ports to ALL protocols, but in one of comments under the same free oracle post you say "[WM: You never EVER want to open ports 22, 80, and 443 for public access to any Asterisk server. It will be compromised. It’s just a matter of time.]"
so now I am confused....
2) doesnt ALL Protocols ALL ports include ports 22, 80 and 443?
thank you!
Hi Ward
2 questions
thank you!
Incredible PBX has its own firewall that blocks port access to 22, 80, and 443.
