wow, that was a quick reply. thank you. What about the other question? stateless yes or stateless no?
thanks
I have the sateless for all protocols as per @wardmundy post somewhere -letting all stateless protocols through the Oracle firewall and letting the Incredible firewall (iptables) take care of blocking most of them. That is just the 1st line of the ingress rules of the OCL firewall. In Ingress Rules below the port 1234 is for whatever number ssh port you have configured and allowed in incrediblepbx iptables as well as in the ssh/sshd_config file
I have the sateless for all protocols as per @wardmundy post somewhere -letting all stateless protocols through the Oracle firewall and letting the Incredible firewall (iptables) take care of blocking most of them. That is just the 1st line of the ingress rules of the OCL firewall. In Ingress Rules below the port 1234 is for whatever number ssh port you have configured and allowed in incrediblepbx iptables as well as in the ssh config file
View attachment 4685 View attachment 4683
I had left it as in the blog post with stateless NO and it was working since install yesterday. but I will change it to YES to avoid problems in the future. Thank you.
ATTENTION
For the moment I'm assuming that no security action is needed in spite of the following email; but it does mention "In the future, Oracle will enforce this policy for all OCI tenancies."
here is text of email received from Oracle Cloud:
Oracle Cloud Infrastructure Customer
Security is a top priority for Oracle. To help improve the security posture of your Oracle Cloud Infrastructure (OCI) tenancy, Oracle is taking steps that will require the use of multi-factor authentication (MFA) for all new tenancies. In the future, Oracle will enforce this policy for all OCI tenancies.
MFA helps reduce the risk of your tenancy being compromised by strengthening the authentication process. Along with your username and password, you will be challenged for a second factor of authentication. Oracle recommends using phishing-resistant MFA devices such as FIDO2 compliant security keys for all cloud administrators.
Immediate Recommended Action: Enable MFA for all Oracle Cloud administrators. To set up MFA using Oracle best practices, see the IAM MFA documentation: https://docs.oracle.com/en-us/iaas/Content/Security/Reference/iam_security.htm#iam_mfa_best_practice
Action Recommended
Service(s): Oracle Cloud Infrastructure
Tenant Name: redacted
What should I do if I am still having an issue?
Click this link to view your available support options.
"https://cloud.oracle.com/support/home"
ATTENTION
Action Recommended
I got that email too. It says this so I'm ignoring it at the moment
Yes that would be the correct response atm for existing tenancy; but for new tenancies and future we will be needing a new recipe maybe some working it out the kitchen.
shodan
