nateornat
- May 15, 2009
- 102
- 9
I have a server running asterisk 18 incredible pbx 15 with a Debian install of incredible pbx 2021.
I am not able to to send or receive any calls with G729. This system is in a low bandwidth area and I need to try and get this working.
Calls do work if I remove the g729 from the trunks and use ulaw. any thoughts as to why g729 wont work here? I believe it comes built into the new installs and i shouldn't have to install anything extra to make this work.?
Your help will be greatly appreciated.
Peer User/ANR Call ID Format Hold Last Message Expiry Peer 209.216.1.221 16026889999 183247776-38620 (nothing) No Rx: INVITE didforsale 1 active SIP dialog PBX*CLI> WARNING[25714][C-0000000f]: channel.c:5692 set_format: Unable to find a codec translation path: (gsm|g722|alaw|ulaw) -> (g729) No such command ' WARNING[25714][C-0000000f]: channel.c:5692 set_format: Unable to find a codec translation path: (gsm|g722|alaw|ulaw) -> (g729)' (ty
