I cleaned out the rules.d but did not have any folder dhcp or dhcpd. Reboot and same thing.
Running "asterisk -c" gets me this:
Running as user 'asterisk'
Running under group 'asterisk'
PBX UUID: ce539827-77f7-4bf6-bda9-78b77e45c812
[2023-03-04 22:42:27] NOTICE[4008]: loader.c:2377 load_modules: 338 modules will be loaded.
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-TravMan4' dsn->[MySQL-TravMan4]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-asteridex' dsn->[MySQL-asteridex]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-asterisk' dsn->[MySQL-asterisk]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-asteriskcdrdb' dsn->[MySQL-asteriskcdrdb]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-mysql' dsn->[MySQL-mysql]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-performance_schema' dsn->[MySQL-performance_schema]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-test' dsn->[MySQL-test]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'MySQL-timeclock' dsn->[MySQL-timeclock]
[2023-03-04 22:42:27] NOTICE[4008]: res_odbc.c:706 load_odbc_config: Registered ODBC class 'asteriskcdrdb' dsn->[MySQL-asteriskcdrdb]
[ Initializing Custom Configuration Options ]
[2023-03-04 22:42:27] NOTICE[4008]: cdr.c:4501 cdr_toggle_runtime_options: CDR simple logging enabled.
[2023-03-04 22:42:27] WARNING[4008]: presencestate.c:200 ast_presence_state_helper: No provider found for label: CustomPresence
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'from-internal-additional' tries to include nonexistent context 'app-recordings'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'paging-chanspy' tries to include nonexistent context 'paging-chanspy-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'dialparties-builddshunt' tries to include nonexistent context 'dialparties-builddshunt-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'dialparties-checkcfextension' tries to include nonexistent context 'dialparties-checkcfextension-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'dialparties-checkcfextensions' tries to include nonexistent context 'dialparties-checkcfextensions-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'sub-send-obroute-email' tries to include nonexistent context 'sub-send-obroute-email-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'from-trunk-sip-IPComms' tries to include nonexistent context 'from-trunk-sip-IPComms-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'ext-did-0002' tries to include nonexistent context 'ext-did-0002-custom'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'ext-did' tries to include nonexistent context 'ext-did-0001'
[2023-03-04 22:42:27] WARNING[4008]: pbx.c:8732 ast_context_verify_includes: Context 'park-hints' tries to include nonexistent context 'parkedcalls'
[2023-03-04 22:42:27] ERROR[4008]: res_config_pgsql.c:1606 pgsql_reconnect: PostgreSQL RealTime: Failed to connect database asterisk on 127.0.0.1:
[2023-03-04 22:42:27] WARNING[4008]: res_config_pgsql.c:1544 parse_config: PostgreSQL RealTime: Couldn't establish connection. Check debug.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1247 load_mysql_config: MySQL RealTime: No database user found, using 'asterisk' as default.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1253 load_mysql_config: MySQL RealTime: No database password found, using 'asterisk' as default.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1259 load_mysql_config: MySQL RealTime: No database host found, using localhost via socket.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1265 load_mysql_config: MySQL RealTime: No database name found, using 'asterisk' as default.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1271 load_mysql_config: MySQL RealTime: No database port found, using 3306 as default.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1283 load_mysql_config: MySQL RealTime: No database socket found, using '/var/lib/mysql/mysql.sock' as default.
[2023-03-04 22:42:27] WARNING[4008]: res_config_mysql.c:1288 load_mysql_config: MySQL RealTime: No database socket found (and unable to detect a suitable path).
[2023-03-04 22:42:27] NOTICE[4008]: dnsmgr.c:493 do_reload: Managed DNS entries will be refreshed every 300 seconds.
[2023-03-04 22:42:27] ERROR[4008]: tcptls.c:770 ast_tcptls_server_start: Unable to bind http server to 127.0.0.1:8088: Address already in use
[2023-03-04 22:42:27] WARNING[4008]: http.c:2216 __ast_http_load: Failed to start HTTP server for address 127.0.0.1:0
[2023-03-04 22:42:27] ERROR[4008]: tcptls.c:770 ast_tcptls_server_start: Unable to bind https server to [::]:8089: Address already in use
[2023-03-04 22:42:27] ERROR[4008]: tcptls.c:770 ast_tcptls_server_start: Unable to bind AMI server to 0.0.0.0:5038: Address already in use
Illegal instruction
I checked that mysql was running and it is. Odd.
