TIPS Problems setting up on windows 11
Liquid
Hey im new to all this stuff and im trying to get it setup on my windows 11 machine along with the windows ubuntu. When I do the pbxstatus command it shows a few of them offline as you can see here.
Also when I tried to open and login with Zoiper 5 It showed this and I used the correct login
if anyone could help or needs more info pls lmk
Those offline applications and not related to your Zoiper issue. You can run the system without them.
Do you have the correct ports specified for SIP / PJSIP?
I’m not sure I didn’t see anything specifying certain ports I just followed the guide
What ports are configured in the Zoiper app?
Which guide did you use?
I didn’t get told to do anything in the app besides Login
You need to do some basic fault finding. It looks like Zoiper can’t find any ports on Asterisk. It may be a network problem so make sure you have a network connection between Windows and Ubuntu.
Is Zoiper on a different network than your PBX? If so, yes.
What does /var/log/asterisk/full show when you attempt to connect from Zoiper??
when i did startup command rn it said ERROR 1356 (HY000) at line 1: View 'mysql.user' references invalid table(s) or column(s) or function(s) or definer/invoker of view lack rights to use them
yesterday it said @noreply.com or something but today it says @mypcname
Look for the connection information. Should be at the bottom of the file after you attempt to connect with Zoiper.
I’m not sure why but it’s not starting now but it was last night. The domain seems wrong like the username is different in the ubuntu vm
tail /var/log/asterisk/full:
[2023-09-23 15:06:22] VERBOSE[3495] res_pjsip_registrar.c: Added contact 'sip:[email protected]:53785;rinstance=cba247c128d967fe' to AOR '701' with expiration of 60 seconds
[2023-09-23 15:06:22] VERBOSE[4807] res_pjsip/pjsip_configuration.c: Endpoint 701 is now Reachable
[2023-09-23 15:06:22] VERBOSE[4807] res_pjsip/pjsip_options.c: Contact 701/sip:[email protected]:53785;rinstance=cba247c128d967fe is now Reachable.  RTT: 57.046 msec
Also what am i supposed to use for the domain where it says fill in host name and select provider from the list?
Maybe im putting the wrong thing?
update- TCP says not found, SIP UDP says found tho IAX UDP also not found. Is this ok?
how do I get web admin panel thing i dont see anything about getting that setup anywhere
