rchalk
- Feb 19, 2010
- 403
- 55
I have successfully created a working IncrediblePBX 2021. Ward mentions the problem of no audio, and recommends a VPN connection. I am however trying to use Obi 200 ATA for home phones, and these do not have VPN capability. Has anyone found a work-around for the no-audio problem? Thanks.TIP: You will save yourself an enormous amount of frustration by deploying an OpenVPN client as soon as your new build comes on line. You then can access it in the traditional way using SSH from anywhere on your OpenVPN network.
