TRY THIS Missing FaxGetty components
cantVOIP
IncrediblePBX 2021.01
Asterisk 18.2.1
Incredible GUI 15.0.22.33
Debian 10
Using vmware version.
Hello everyone, I have an issue with one of my IncrediblePBX servers.
This one specifically has FaxGetty DOWN. When I run ./iaxmodem-restart I get an error saying that certain lines do not exists
Under /usr/local/sbin/faxgetty there's the following:
The first thing that came to my mind was changing the file iaxmodem-restart entries to faxgetty2 to match what is in that path. The issue persists.
I've found a workaround which is to go directly to the path /usr/local/sbin and run the commands directly:
faxgetty -D ttyIAX0
faxgetty -D ttyIAX1
faxgetty -D ttyIAX2
faxgetty -D ttyIAX3
I would like to be able to run ./iaxmodem-restart instead of doing the workaround. Thank you for your help! And I hope the prior helps people who want to get FaxGetty UP and rruning
It's obviously finding faxgetty somewhere in your path. Run the command below and then copy the path to the iaxmodem-restart script.:
find / -name faxgetty
It's under /usr/sbin/
Do you recommend changing ./iaxmodem-restart path to match /usr/sbin/faxgetty -D ttyIAX0?
