extentions custom conf
spr41178
Hello,
Does anyone happen to have the original extensions.custom.conf file that is being set-up on the
raspberrypi Incrediblepbx2027D install?
I lost my original after fiddling with it and i accidentally deleted my backup file
Thank you
It's actually extensions_custom.conf , I don't have a 2027D, my Oracle install is 2027U. They should be much the same and if you have the tar file you should find it in there.
Thanks Dallas,
Much appreciated.
