TIPS MS Teams - SIP/2.0 403 Forbidden due to IP instead of FQDN Transported?
zwangzw
Hi All,
I would really appreciate if anyone had similiar experience on troubleshooting this.
Server: Ubuntu 22.04 / Asterisk 20.8.1
I have followed the wiki instructions on https://incrediblepbx.com/teams/. Notably:
1. Applied the Asterisk patch script mentioned in the wiki page
2. Obtained Certificate from LetsEncrypt that matched the FQDN
3. ms_signaling_address is set to FQDN (DOMAIN.COM) at /etc/asterisk/pjsip.transports_custom_post.conf
PJSIP had issues to communicate with 403 Forbidden error as below
<--- Received SIP response (677 bytes) from TLS:52.114.148.0:5061 --->
FROM: <sip:[email protected]>;tag=4f571543-7686-4ae7-b753-2b14ee159ca7
TO: <sip:sip.pstnhub.microsoft.com>
CSEQ: 5023 OPTIONS
CALL-ID: 0620fdb4-43c1-47cf-a211-4fb79fecbcab
VIA: SIP/2.0/TLS DOMAIN.COM:5061;branch=z9hG4bKPj0c86fbee-c418-4475-918e-3fb22af2b63f;rport
REASON: Q.850;cause=63;text="51182690-a6d0-41b1-8561-2c4467791d1d;SBC certificate is not issued correctly. Provided trunk FQDN '1.2.3.4' is not included in certificate's CN or SAN list. Certificate allows following FQDNs only: DOMAIN.COM."
CONTENT-LENGTH: 0
ALLOW: INVITE,ACK,OPTIONS,CANCEL,BYE,NOTIFY
SERVER: Microsoft.PSTNHub.SIPProxy v.2024.4.11.1 i.USWE2.9
Am I missing something?
Many thanks,
I'm not sure why you got a cert for this, it doesn't apply. Show the transport you created and a full debug of the INVITE the 401, the INVITE in response to the 401 and then this 403...what does the original INVITE look like?
Thanks all.
I tried hard coded the FQDN on res_pjsip_nat.c on a plain vanilla Asterisk (both latest version 20 and 21) as well as used acme.sh to obtain certificate from letsencrypt - it worked now.
I will investigate further if its the Certificate Manager that is behaving weird or some of the patches from IncrediblePBX no longer work.
Did you get any further with this? Just about to install a new instance of Incredible PBX for integrating with Teams, or should I go vanilla asterisk for now?
rhys96999
