sridharaon
- Aug 13, 2024
- 7
- 0
I'm currently experiencing a strange issue with my Incredible PBX setup. The setup is running behind a pfSense firewall. Here’s the problem I’m facing:
Issue: When making calls using IP iPhones (specifically, hardware-based SIP phones), there's no audio on the calls. However, when I switch to softphones on the same network, audio works perfectly fine.
Setup Details:
PBX Software: Incredible PBX
Firewall: pfSense
Softphone Software: Zoiper
Network Configuration: Both the softphones and IP phones are on the same local network.
I'm at a bit of a loss as to what could be causing the discrepancy between the softphones and the IP phones. Any insights or suggestions on what to check or adjust would be greatly appreciated.
Thank you in advance for your help!
Setup Details:
Firewall: pfSense
