TIPS Backup Module Not Storing Changes
spr41178
Good afternoon,
Noticed on a RasPi version that if i want to change a setting on the Backup Module it doesn't change, i have to delete the whole task then reenter it with
the changes i want and then it works.
Is it a bug in the module?
See if running the following command from the CLI helps:
fwconsole chown
fwconsole chown
Hi Ward,
Had already tried the above command, hasn't helped, the phonebook is ok i was making a mistake. It is only the backup module, i have tried upgrading it and downgrading it but the outcome is the same
That backup bug has been around since FreePBX-16. The only way to change the backup is to delete it and re-enter it. Again, you are welcome to file a bug report over at the FreePBX site I listed above. It is not an IncrediblePBX issue.
I do note that changes to an existing backup work correctly in FreePBX-17.
As to the Asterisk Phonebook, I can't comment as it is working for me on FreePBX-16 and not available on FreePBX-17. You may have a corrupted installation on your RasPi.
Thank you sir for your reply,
Mind you on 12 separate instances of FreePBX 16 that i have it works fine.
Thought it was a Raspberry Issue with IncrediblePBX.
It doesnt bother me to change it manually and add the task again.
Educationalwise i asked in case that was associated with problems elsewhere in the code.
Kind thanks to everyone and have a nice day.
kalilinux
