TIPS Modify /etc/asterisk/pjsip.transports.conf file
cantVOIP
Hello everyone,
I've setup let's encrypt to IncrediblePBX server. It renews the certificates automatically through DNS challenge.
The process gets .pem files for the private key, fullchain and, chain creates a shortcut at /etc/letsencrypt/live/mydomain.com/*.pem and the actual files are located under /etc/letsencrypt/archive/mydomain.com/*.pem
How can I edit the pjsip.transports.conf to include pjsip.transports_custom.conf and overwrite the section of the certs to the /etc/letsencrypt/live/mydomain.com path?
[0.0.0.0-tls]
type=transport
protocol=tls
bind=0.0.0.0:5061
cert_file=/etc/letsencrypt/live/yourdomain.com/fullchain.pem
priv_key_file=/etc/letsencrypt/live/yourdomain.com/privkey.pem
ca_list_file=/etc/letsencrypt/live/yourdomain.com/chain.pem
method=tlsv1_2
I'm currently having to manually copy the actual files from /etc/letsencrypt/archive/mydomain.com/ to /etc/asterisk/keys and then rename the files from .pem to .crt and .key. If I try to include pjsip.transport_custom.conf to pjsip.transport.conf it gets overwriten whenever the server reloads. I've tried to create a shortcut from /etc/asterisk/keys pointing to the right certs but it does not work. Any suggestions?
You can change the permissions of /etc/letsencrypt/{live,archive} to 0755 so that asterisk can read the files. Then a symbolic link should work.
Use the `fwconsole cert --import` command to import the cert into Certificate Manager and then set that in Asterisk SIP Settings. No need to hack the custom pjsip transports file.
