ostridge
- Jan 22, 2015
- 1,816
- 630
Have raised a ticket about this even though this is a 3 year old PSU I/P 100-240v 50~60 hz 5.5amps AC ; O/P 18watt 5.25volts dc 3.5amps from Argon40.com website. Its double insulated so the earth (ground) pin on the PSU is plastic just to operate the shutter which allows the plug to enter the socket
The RPI 4b in an Argon40 case I noticed had stopped, and noticed sparks when disconnecting the hdmi cable (attached to a monitor)
Test as photo measured voltage relative the green wire conected to 'Earth pin of a uk plug = house ground (earth to me).
If you have one of these even with US type there is possibility of similar failure.
fault to power supply.
